Help overclocking F4-4000C19D-32GTZR on asus maximux XI extreme with i9 9900k
hm!
DRAM Voltage to 1.45V for test, will it help?
Vccio voltage to 1.15v
Cpu system agent voltage to 1.25v
dram voltage to 1.45 v
and can you please check the timings from tRDWR_SG, tRDWR_DG, tRDWR_DR and tRDWR_DD
if they are lower than your tCL can you set them to 19, 19, 19, 20 ?
- i can remember a posting about Asus problem and that helped to set them not faster than tCL ( but here we need a pro, i can`t explain that )Last edited by hq-hq; 01-03-2019, 11:28 AM.
Hi! Sorry, I had to leave home to run herrands.
The pc did NOT but with this setting at 3800 mzk :-(
I am not sure where are in the bios the timings from tRDWR_SG, tRDWR_DG, tRDWR_DR and tRDWR_DD (see attached pictures)
I have downloaded mem tweakit. I just installed it but it seems none of the option are available for me to change
. Is this an old software for old motherboards and that is why it is not working?2 PhotosLast edited by marcolisi; 01-03-2019, 05:25 PM.
wow, your board uses on automatic sharp timings - like
could be it is a little bit too optimistic :-D
@3600 it uses 15 15 15 36 and so on
so we can loosen them up a little bit :
please set:
tCAS 17
tRAS-CAS 17
i think automatic logic will set the others based on them also a little bit higher *hope so*
- if it will not work you can try tCAS 19 and tRAS-CAS 19 too
and somewhere deeper in the bios settings must be secondary and tertiary timings
this style:
DRAM READ to WRITE Delay sg = tCAS
DRAM READ to WRITE Delay dg = tCAS
DRAM READ to WRITE Delay dr = tCAS
DRAM READ to WRITE Delay dd = tCAS +1
--- Mem TweakIt
ok, it should work with z390 but maybe they locked it for "ROG"- i don“t know
example advertising
https://www.asus.com/us/Motherboards...pecifications/Last edited by hq-hq; 01-04-2019, 02:10 AM.
- 1 like
tCAS = DRAM CAS# Latency
tRAS-CAS = DRAM RAS# to CAS# Delay
please set DRAM CAS# Latency and DRAM RAS# to CAS# Delay to 17 (if it is not working please set it to 19)
look for third timings:
tRDWR_sg set to DRAM CAS# Latency
tRDWR_dg set to DRAM CAS# Latency
tRDWR_dr set to DRAM CAS# Latency
tRDWR_dd set to DRAM CAS# Latency + 1 [ for example 17 + 1 = 18 ]
and check please:
tWRRD_sg = ~30
tWRRD_dg = ~25
tWRRD_dr = 4 to 5
tWRRD_dd = 4 to 7
if they are lower please set them to 30, 25, 5, 7
to mem tweakit
on asus homepage i see it is advertised for z390 asus rog mainboard, but i cant find download link, newest version i can find is 20170830 but it is for x299 platform :-/
http://dlcdnet.asus.com/pub/ASUS/mb/...8_20170830.zipLast edited by hq-hq; 01-05-2019, 05:57 AM.
