No problem, let us know if it's better
ASrock Z77 Extreme4 + F3-17000CL9Q-16GBXM
So I went and just looked at the ASRock bios section and found something strange. For the ASRock Z77 Extreme4 motherboard, there have only been bios versions 1.1, 1.2, 1.3, 1.4, 1.8, and 2.0. You mentioned version 1.6. Are you thinking of another motherboard, or would they not list it on their page?
Don't know why they pulled it, I've got all the version saved in a folder, might try 1.4 if any problems w/ 2.0, 1.4 fixed most of the things I was working with them on i.e. 16/32GB sets of 2133 and up as far as the tRFC and secondary timings
Originally posted by Tradesman View PostDon't know why they pulled it, I've got all the version saved in a folder, might try 1.4 if any problems w/ 2.0, 1.4 fixed most of the things I was working with them on i.e. 16/32GB sets of 2133 and up as far as the tRFC and secondary timings
Originally posted by Tradesman View PostCheck your email, it's attached (8 MB)..put it on a flash drive and can flash direct through BIOSI guess I'll contact Newegg tomorrow and see if they are willing to let me RMA the board to them. At this point, I'm actually worried about sticking with ASRock because of these difficulties with the memory I have been having.
What's sad is that we actually were able to get 2133 to work but that issue with it not booting if the system was completely powered down, even after I kept increasing the voltage.
But, in the meantime, any other suggestions?
Originally posted by Tradesman View PostLet me know if it helps
Originally posted by Tradesman View PostTo check the issue after completely powered down, we hit 2133 earlier, but after the complete power down it wouldn't restart right? Thinking PSU may be fluctuating, especially on a cold boot
Originally posted by Tradesman View PostCould well be, just trying to cover all the possibilities......I hate to have to RMA and then find it was something else
