Hello Everyone.
This is my first post, the reason why I joined this community. First of all, my name is Augusto and I'm from Buenos Aires, Argentina. (I'll later create a thread introducing myself)
The point is that I bought these 2GBx2 DDR3 pack. The blue ones.
F3-12800CL8D-4GBRM
DDR3-1600 PC3-12800 2GBx"
XMP CL8-8-8-24 1.6v
And I also bought this:
Asus P8H67-M PRO (Revision 3.0)
The point is that I didn't check If this mother supported 1600Mhz DDR3 (i knew about the DDR3, but not if it supported 1600MHZ). And in 4 from 6 PC Stores, when I mentioned this motherboard and 4GB Kingston 1333Mhz, they all said: With your configuration, This will work better... (and they presented me this 2GBx2 ripjaws 1600).
So the point is that I have only bought yet, the processor (intel i5 2500 S1155), this motherboard, the RAM Modules and the Power Supply. So, my PC isn't working ATM.
I really really need to know if there's a chance that this config (regarding to the RAM/MOTHER issue) will work well..
I checked the Qualified Vendor List from ASUS about my mother and there are some gskill RAM modules:
G.SKILL F3-10600CL8D-2GBHK(XMP) 1GB SS
G.SKILL F3-10666CL7T-3GBPK(XMP) 3GB(3 x 1GB) SS - - 7-7-7-18 1.5~1.6V
G.SKILL F3-10666CL9T-3GBNQ 3GB(3 x 1GB) SS 9-9-9-24 1.5~1.6V
G.SKILL F3-10600CL9D-2GBNQ 1GB DS
G.SKILL F3-10600CL8D-4GBHK(XMP) 4GB(2 x 2GB) DS - - 8-8-8-21 1.5-1.6V
G.SKILL F3-10666CL8D-4GBECO(XMP) 4GB(2 x 2GB) DS - 8-8-8-8-24 XMP 1.35V
G.SKILL F3-10666CL7T-6GBPK(XMP) 6GB(3 x 2GB) DS - - 7-7-7-18 1.5~1.6V
G.SKILL F3-10666CL7D-8GBRH(XMP) 8GB(2 x 4GB) DS - - 7-7-7-21 1.5V
G.SKILL F3-10666CL9D-8GBRL 8GB(2 x 4GB) DS 9-9-9-24 1.5V
The official webpage for this ram modules (http://www.gskill.com/products.php?index=221) say that it works with P55 intel chipset. But the P55 works with socket 1156, and my processor is 1155..
Please Help Me! :S
Thank You very much in advanced.
Regards, Augusto
F3-12800CL8D-4GBRM
XMP CL8-8-8-24 1.6v
Please Help Me! :S
Regards, Augusto
