You can contact the RMA folks direct at rma@gskillusa.com and I'll drop GSkill Tech a note to take a look, it will be probably be Mon or Tues as they are off on weekends, though if you don't want to OC at all (which is needed for 2400), at 1600, I'd tighten the timings down, if these are indeed 2400/11 sticks dropping to 1600 most would tighten down to more like 8-8-8-24 (and 1866 9-9-9-27 or 2133 10-10-10-30).
F3-19200CL9Q-16GBZHD Issues
Originally posted by Tradesman View PostYou can contact the RMA folks direct at rma@gskillusa.com and I'll drop GSkill Tech a note to take a look, it will be probably be Mon or Tues as they are off on weekends, though if you don't want to OC at all (which is needed for 2400), at 1600, I'd tighten the timings down, if these are indeed 2400/11 sticks dropping to 1600 most would tighten down to more like 8-8-8-24 (and 1866 9-9-9-27 or 2133 10-10-10-30).
Sorry then I'm lost, you've been saying everything on the CPU is at stock and even stressing that point,
"No, I'm not OCing the CPU as I wanted to get the RAM stable first"
"With the CPU at stock speed "
. I'll bow out and let Gskill work with this, already dropped a note to them
Originally posted by Tradesman View PostSorry then I'm lost, you've been saying everything on the CPU is at stock and even stressing that point,
