Im currently running windows 7 64 bit with an ASUS M4A89GTD PRO and the sniper 8 gig (2x4) RAM Model F3-12800CL9D-8GBSR. I followed the guidelines in your RAM setup but whenever I use both sticks of ram in dual channel I get system instability. Ive RMA'd this motherboard once already and that didnt solve the problem because I assumed a bad memory controller because it was stable with only 1 stick. I'm not quite sure how to troubleshoot higher end ram because this is my first build with more than 4 gigs of ram.
I have the windows memory diagnostic logs just in case that would help, Im just not sure how you want me to post them here.
