DDR3 F3-12800CL9-2GBNQ help
  • DDR3 F3-12800CL9-2GBNQ help
    i just updated bios and everything trying to get this PC running at its best. but i dont think the RAM config is right and to be honest i dont know how to fix iit lol
    anyhelp would be appreciated
    If you want to run them at 1600 take a look at the sticky:
      I tried that, but in bios i didnt see FSB and so on options and then when i put my RAM to 800 1600 it just blue screens and so on. im not sure what im missing exactly oh oh and also why do 2 sticks look like they're running at different speeds than the other 2?
        What motherboard do you have?
        The "speed" is the same, they just have different profiles. You don't need to worry since you need manual settings anyway.
          my mobo is Asus M4A785TD-V EVO
          do you know the program they have for their boards the "TurboV"
          is this how i would change the NB voltage's and CPU frequency because
          this is the only thing ive seen with these options.
            FSB = Bus Speed = CPU Clock, default is 200MHz
            Your board may have a default setting for 800 (1600MHz), otherwise you would need to increase the CPU clock.
            Then manually enter the memory timings and DRAM voltage (1.50v) in your bios.
            ASUS Crosshair V Formula
            Creative SB X-Fi Xtreme Gamer
            Corsair HX850W Modular
            2x Win 7 Home Premium (x64)
              You can change them directly in BIOS. (Press Del when you start up computer).
              TurboV is done in Windows, then it will send settings to BIOS.
