Hello all,
I have recently bought an ASUS m4n68T-m motherboard with an Athlon II regor 245 (2.9Ghz) CPU with 4 GB f3-10666cl9d-4gbrl
For a while the machine has been running well (about 4 months) but recently the machine started the freeze after some use. 20% of times I get BSOD, 80% it just hangs and I need a hard boot. The frequency of freezing has increased to the point where I now cannot run the pc longer than 5 minutes, sometimes the pc even freezes coming into the windows desktop. I have even managed to freeze it during the MoBo splash screen.
I ran memtest86+ several times. Usually it freezes, only once or twice (after 25x attempts) it actually posted errors. Mostly it just freezes, num-lock light does not respond and tests do not update.
The power supply is a classy Corsair 400W. The video card an ATI 4850 which should all have ample power (especially at idle).
The BIOS has been flashed and updated. The settings are all at auto and I have never overclocked the machine. None of the components feel excessively hot, although I do notice that after a crash, I get a longer performance if I let the machine rest for a bit.
I am debating whether this is Mobo settings problem or a Gskill memory problem. Any suggestions?
