All right, keep us updated, we'll be around
Z68x-ud7-b3 upgraded 16GB Cant post 2133
Don't have to tell me about that, I try to keep three systems up tight, but also use these same ones to test components that I pick up to test with, or pull from other systems to troubleshoot individual components, etc...it can be a real pain and drive you crazy
Well i swapped out the Ram to the RipJaw-X series, and there doing the same exact thing.. Any time i select a Profile (there are 2 profiles it gives me, one looks like its 2000 mhz, the other 2133).. As soon as i save the bios, the system shuts down, goes to restart, goes off again, then turns on and resets my overclock back to 3.4 chz and says the system has experienced boot failures because of ocerclocking of changes of voltages..
I am really ticked now.. These are CERTIFIED peices of Ram, BOTH sets, and they arent able to hit 2133?!??
Addition, just as before.. If i set the ram to 1600Mhz, My usual OC of 4.8 on the 2600K, I am able to boot no issue, bios doesnt restart on saving, get into windows etc... Look totally stable. So wtf am i missing here that this board wont push these sticks to 2133??
The 4GB sticks (Part # F3-17000CL9D-8GBXLD) work 100% fine.
Doesn't make sense to me, wish I could get my hands on it. Can you enable XMP and post your BIOS settings for CPU OC, system voltages and DRAM timings (both base and the advanced/secondary timings)?
CPU Clock Ratio -[48x]
BCLK/DMI/PEG - [100.3]
EXTREME MEMORY PROFILE (X.M.P) -[PROFILE 2]
SYSTEM MEMORY MULTIPLIER - [21.33]
-ADVANCED MEMORY SETTINGS-
XMP [PROFILE 2]
SPD [21.22]
PERFORMANCE ENHANCE [STANDARD] (tried turbo and extreme)
DRAM TIMING SELECTABLE (SPD) [EXPERT]
Profile DDR Voltage - 1.6V (Non Changeable)
Profile VTT Voltage - 1.1V (Non Changeable)
Channel Interleaving [AUTO]
Rank Interleaving [AUTO]
Timings (both Channel A/B) 9-11-11-31-2T
(Other timings) 42-6-8-16-27-7-22-8-25, io latence 1, round trip 34
--VOLTAGES--
MULTI-STEPS LOAD-LINE [LEVEL 7]
CPU VCORE [1.440V]
QPI/VTT Voltage [1.200V] (have tried 1.10, and Auto
System Agent Voltage [AUTO] Have gone up to 1.205V]
PCH Core - Auto (1.050V)
CPU PLL - Auto (1.800V)
DRAM
DRAM Voltage - [1.600V] - shows 1.500V
DRAM VREF. -Auto (0.750V)
DRAM Termination, CH-A Data Vref, B Data Vref, Address V-REfs are all Auto (0.7500
Antying else you need?
