Z68x-ud7-b3 upgraded 16GB Cant post 2133
  • Z68x-ud7-b3 upgraded 16GB Cant post 2133
    Short and simple.. I just upgraded from my G-Skill Ripjaw-X F3-17000CL9D-8GBXLD (8 Gig) to F3-2133C9D-16GTX Trident-X (16GB) and my overclock seems shot in the foot at Any ram speed over 1600..
    I was at 2133 and humming along with XMP on at 4.8 GHZ on my 2600K.. Now If i go past 1600 it boot loops the bios til it comes back to 1333 speed and i have to reset it again.
    Tried diferent slots, im on F9 bios, about to update to F10 to see if that fixes issue..
    Ideas?
    I also had QPI up to 1.22, Set D-Ram volt to 1.60 but i think its stuck on 1.5 (I saw someone else post something similar in a search)..
    Please help!
    Let us know how it goes with the BIOS update, hopefully that will also clear up the DRAM voltage problem, I was going to suggest 1.55 Dram voltage and 1.25 QPIVTT
      Well it didnt do Jack.. Now on F10 and still boot looping on 2133.. Let me try your suggestion.
        Just of note, its not running 2133 at STOCK CPU Speed.. No Overclock.. This is absolutley HORRIBLE.. At this pace i may junk the 16GB and stick with the 8 that was at 2133..
          Tried changing the slots again, Nothing.. I set 2133 either manually or selecting Profile 2 in XMP (prifile 1 seems ot be or 2000, that dont work either), and Im getting No-where. This ram was Certified for this board and its being a certified pain in the A**.
          Should i just leave the 8 in and forgo the 16 and return it? The 8 ran like a champ never had an issue.
            What's the VCCSA at? try it at 1.2, then if that helps try dropping it in small increments while maintaining stability
              What is a VCCSA?? I see nothing in the bios that says that.. I see QPI.VTT (which is at 1.100V) right now, i have a funny feeling that is what your talking about so im putting that at 1.2, i had it at 1.22 before and didnt do jack.
                Is that the DRAM VREF. ???
                  Lemme guess, System Agent Voltage?? Its 0.925V right now.
                    Yes system Agent Voltage is VCCSA (1.2) and the QPIVTT at 1.25
                      Trying now, there is no 1.2 and 1.25.. So its going to 1.205 (VCCSA) and 1.260 QPI. Trying Profile 2 for 2133.
                        Nope.. It shuts down on bios save.. Turns back on (itself), turns back off after about 3 seconds, and tells me its Failed overclock because of voltages etc..
                          This is how frustrating this is... I'm out getting something to eat now cause I was gonna commit a violent act on that ram... call me the ram oj.
                            What OC do you have on the CPU?
                              None I went back to stock 3.4
                              No oc at all right now. Was at 4.8 stable as a rock.
