I just bought ASUS Crosshair V Formula-Z and I'm going to use all 32GB of RAM but I'm not sure which RAM to buy. I want 32GB, I can't use less. Some of you might think "wow, what on Earth could Yuji be doing?..." I've bought the AMD FX-8350, 8 Cores S@ 4.0 Ghz, T@4.2 Ghz. Without overclocking the CPU, what's the "best" RAM I could use? I don't much care for overclocking this CPU if that makes a difference. Any help would be most appreciated.
I believe the following two 'packages' might be best appropriate? F3-1866C9Q-32GZH and F3-1866C8Q-32GTX. The only differences I see are the tested latencies and voltage. 9-9-9-24 2N 1.5V and 8-9-9-24 2N 1.6V respectively. I do wonder if this motherboard and processor can support this though... I'd like to know also how to read those Model Names. I understand from 1866 to C9 but not Q, and everything past 32.
Reading the motherboard specifications again, I notice it says it supports ECC modules. Does G.SKILL even produce ECC modules? (This too is something I'd want. I know, slight performance loss...but I might need it, heh, depending on the price difference...) More specifications shows this motherboard supports XMP/DOCP profiles? That would go best with the latter RAM too...Also supports F3-19200CL10Q-32GBZHD (32GB, 4 x 8GB) 10 12 12 31 1.65V...Could the CPU (AMD FX-8350)?
*Edit*
If G.SKILL had an IRC...you might wonder if it'd be packed.
*Edit*
