Originally posted by Tradesman
View Post
Here are my settings:
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: Auto
CPU Clock Ratio ..........................: 8x
Fine CPU Clock Ratio.....................:.+0.5x
CPU Frequency ...........................: 3.40Ghz (400x8.5)
Clock Chip Control
Standard Clock Control
CPU Host Clock Control..................: [Enabled]
CPU Host Frequency (Mhz) ............: 400
PCI Express Frequency (Mhz) .........:100
C.I.A.2 .................................:[Disabled]
Advanced Clock Control [Press Enter]
CPU Clock Drive...........................: <<< 800
PCI Express Clock Drive.................: <<< 900
CPU Clock Skew (ps)....................: <<<
MCH Clock Skew (ps)...................: <<<
DRAM Performance Control
Performance Enhance...................: [STANDARD]
Extreme Memory Profile (X.M.P.).....: Disabled
(G)MCH Frequency Latch...............: [Auto]
System Memory Multiplier ..............: 2.60D
Memory Frequency (Mhz) 1066..............: 1066
DRAM Timing Selectable ................: [Manual]
Standard Timing Control
CAS Latency Time........................ 5 [5]
tRCD ......................................... 5 [5]
tRP'........................................... 5 [5]
tRAS.......................................... 15 [15]
Set all Suggested below to highest Values first. Then later you can lower, one at a time, testing as you go
Advanced Timing Control
tRRD........................................... 4 [Auto]
tWTR.......................................... 4 [Auto]
tWR............................................ 13 [Auto]
tRFC........................................... 68 [Auto]
tRTP........................................... 4 [Auto]
Command Rate (CMD) ....................:0 [2]
Driving Strength Profiles
Driving Strength ............................ Auto
Channel A
Static tRead Value.........................:8
tRD Phase0 Adjustment...................:Auto
tRD Phase1 Adjustment...................:Auto
tRD Phase2 Adjustment .................:Auto
tRD Phase3 Adjustment..................:Auto
Trd2rd(Different Rank)....................:Auto
Twr2wr(Different Rank)...................:Auto
Twr2rd(Different Rank)...................:Auto
Trd2wr(Same/Diff Rank)..................:Auto
Dimm1 Clock Skew Control...............:Auto
Dimm2 Clock Skew Control...............:Auto
Channel B
Dimm1 Clock Skew Control...............:Auto ps
Dimm2 Clock Skew Control...............:Auto ps
Motherboard Voltage Control
CPU
CPU Vcore….……….........................: 1.1875 [1.20625]
CPU Termination…..... 1.200V*.......: 1.200V
CPU PLL…………………....1.500V*.......: 1.500V
CPU Referen.…………....0.755V*.......: Auto
CPU Reference2………,,0.800V*.......: Auto
MCH/ICH
MCH Core…………….....1.100V...........: 1.200V
MCH Reference….…….0.760V...........; Auto
MCH/DRAM Ref.…......0.900V...........: Auto
ICH I/O……………….....1.500V............: 1.500V
ICH Core…………...……1.100V............: 1.100V
DRAM
DRAM Voltage ……....1.800V............: 2.100V
DRAM Termination .…0.900V............: Auto
Channel A Reference 0.900V............: Auto
Channel B Reference 0.900V............: Auto
Advanced Settings
Limit CPUID Max. to 3.....................: [Disabled]
No-Execute Memory Protect............: [Enabled]
CPU Enhanced Halt (C1E)................: [Enabled]
C2/C2E State Support....................: [Disabled]
x C4/C4E State Support..................: [Disabled]
CPU Thermal Monitor 2(TM2) ...........: [Enabled]
CPU EIST Function.........................: [Enabled]
Virtualization Technology................: [Enabled]
Integrated Peripherals
Legacy USB Storage Detect ..............[Disabled]
Clock Chip Control
Channel A
Channel B
CPU
MCH/ICH
DRAM
Advanced Settings
A billion errors in 20 seconds.
I then tried my second RAM stick and put it in slot #2. By now, I am certain that my mobo has a dysfunctional slot #1 and #3.
Does that mean that my second RAM stick is bad?
Also, the reason why I ran MemTest was because I had OCed my system to 3.825Ghz with 2 sticks at 800Mhz speed. Things were going perfectly up until the 7th minute when it froze:
