KM780MX N-key, randomly created macros and invisible assignments
  • KM780MX N-key, randomly created macros and invisible assignments
    I had the KM780MX for a whilel. Few months ago the option to set up N-Key started showing as greyed out. Also for some reason I checked the other day and I had nearly 300 macros that I didn't create, that looks like contains impossible macros that can't be created by a human. Also there are some keys that get assigned to macros randomly without me doing it.
    Am I the only one having this problems?
    Sorry if it is a repeated post but I search for this simptoms and I couldn't find anyone with them.
    Thank you very much.
    Which firmware version are you using? If problem persists, try a reset to see if it that can solve the issue.
    https://www.gskill.us/forum/forum/pr...irmware-update
      I'll try to reset it today, thanks
        My N-Key option won't allow me to select it. I click on it and nothing happens. Firmware 77. Software 2.04.
          Reset random created macros has been fixed, but the N-key option is still greyed out. Any suggestions?
            Do you have the switch on G setting?
              I will check on it thank you
