Dear users,
I want to build a PC based on AsRock fatality AB350 gaming k4 motherboard, with a processor Ryzen 5 1600, so now my problem is to choose RAM properly. On the AsRock website I couldn't find this memory in the QVL list:
Gskill DDR4 TridentZ RGB PC25600 16GB (2x8GB) Dual Channel F4-3200C16D-16GTZR.
Will it work properly with current configuration or should I change it?
I also have an option of Gskill DDR4 RipjawsV PC21300 16GB (2x8GB) Dual Channel F4-2666C15D-16GVB, but again it is not listed on motherboard's QVL list.
PS
They have the same price, which fit my budget. If you have any suggestions please let me know.
PS
