TridentZ, Ryzen 5 1600, Asrock AB350 Gaming K4
  • TridentZ, Ryzen 5 1600, Asrock AB350 Gaming K4
    Dear users,
    I want to build a PC based on AsRock fatality AB350 gaming k4 motherboard, with a processor Ryzen 5 1600, so now my problem is to choose RAM properly. On the AsRock website I couldn't find this memory in the QVL list:
    Gskill DDR4 TridentZ RGB PC25600 16GB (2x8GB) Dual Channel F4-3200C16D-16GTZR.
    Will it work properly with current configuration or should I change it?
    I also have an option of Gskill DDR4 RipjawsV PC21300 16GB (2x8GB) Dual Channel F4-2666C15D-16GVB, but again it is not listed on motherboard's QVL list.
    PS
    They have the same price, which fit my budget. If you have any suggestions please let me know.
    @Rombat
    This is the best way to tell which G.SKill DRAM will work: https://www.gskill.com/en/configurator
    Also: Be careful if choosing Trident ZRGB, the software is very buggy in "beta" (alpha) and using any other RGB software can cause SPD corruption or dimming/ loss of control of your lights. EVEN CPU-ID con cause issues unless you have the newest version 1.79.1
    Cheers
      QuantumsEdge,
      Thank you for your reply.
      Motherboard ASROCK ab350 gaming k4 supports RAM frequency +3200 for Ryzen processors.
      Gskill configurator only giving me suggestions of Ram maximum 2400 MHz for that model of motherboard.
      That's why I'm confused, because I was hoping to get frequency at least 2666
        @Rombat
        Yes I see the same thing you are stating on the website: http://www.asrock.com/MB/AMD/Fatal1t...20K4/index.asp
        G.Skill configurator factors in motherboard but not CPU and the 3200 seems to correspond to this, as stated on ASrock website.
        According to AMDs website the Ryzen 5 1600 supports DDr4 in 2 channel but does not state the maximum capacity or frequency for this processor. https://www.amd.com/en/products/cpu/amd-ryzen-5-1600
        I'm still trying to find more info.
        edit: according to the wikipage for Ryzen 5 1600: https://en.wikichip.org/wiki/amd/ryzen_5/1600 , 2666Mhz is the maximum DRAM frequency that Ryzen 5 1600 can support, if you want faster speeds than that you may need to get a step-up in processor from there, but I don't think it will make too much of a difference.
          QuantumsEdge,
          Now My question is, if I'm using
          Will my motherboard downgrade it to the 2400 MHz or it will run with native PC21300 type 2666 MHz .
          Or should I just choose RAM with 2400 mhz?
            Originally posted by rombat View Post
            QuantumsEdge,
            Ok, i got it. I will be able to increase frequency by unlocking the RAM, but because of the processor limit it could be 2666 MHz maximum.
            Thank you QuantumsEdge
