Originally posted by G.SKILL
View Post
Another thought is S.Skill sells the Flare X kits (for AMD) as DDR4-3200. The specs on those look identical to the TridentZ RGB (14-14-14-34). I do not see any reference there that you may not be able to reach 3200MHz if you are using a Ryzen 1700. What is different about those kits that would allow you to hit 3200MHz?
