Then you'll prob be perfectly fine at 2T, very people can tell the difference between 1 and 2T visually or by the way the system responds, I can with some sets, but very few, and I work with systems every day
Help with F3-12800CL9D-8GBSR + M5A78L-M LX + AMD FX-6100
Hello!
Well guys ... The Tradesman helped me a lot with the setup of my memory (so far not had any problems with blue screens!)
I wish someone could help me / take my question:
From 2200MHz to 2400MHz in NB, give a significant difference in the system?
What a beauty voltage, for me to use in NB, with 2400MHz? (I've used with 1.2v but back in half, at startup, not always clear, the screen was all black and the PC restarted)
Will 1.23 or 1.25V would be too high for the NB?
Any recommendations?
Hello, good night!
Well, as here I was treated very well and very well assisted, I decided to come here to try out a doubt.
What would be:
VDDNB Over Voltage (Would the NB voltage?)
Chipset Over Voltage (Voltage NB or SB?)
I think my northbridge needs a bit more Vcore (from time to time, when I'm starting Windows, when you will see the desktop, the screen just goes black! The PC does not even restart, still a good, just not the system appears, and when I reset back to normal), I put VDDNB to 1.25V, but by the voltage it is AIDA64 1.1675v and Chipset Over Voltage, is in self.
This chip was the NB?
No more, thank any additions!
