Dear Experts,
Please help me;
I have unlocked 4 cores on the Phenom II x2 550 Black Edition using the Motherboard M4A79XTD EVO AM3.
Initially I ran 2x2gb DDR3 G.SKILL 12800CL7D ram. I then bought another 2 sticks, identical make. I tried installing but got BSOD, I knew i had issues back then so I ended up removing one stick. So I ran the system with 2x on dual channel and 1 x on one of the 2 additional slots.
Recently I upgraded to an SSD and made a clean, fresh installation following typical guides etc. Right away I ran into major issues. I tried installing with all 4 sticks and got mass BSOD each time during installation, until I remember my issued a while ago. So I removed a single stick and it worked flawlessly.
Now, I am trying to reinstall the sticks and keep getting issues. It just wont accept the 4rth Stick. I don't think it is a hardware problem as I ran windows diagnostic tests on EXTENDED, several passes - over night. No problems on the logs the next day.
Besides, I had replaced each stick randomly and used each of the slots on the motherboard and got same result.
I read somewhere that If I dont configure my memory correctly in BIOS< it may cause BSOD. So I checked my BIOS and found that everything was set to AUTO and hence it will make everything run at slowest rates.
My CPU is set through the overdrive at 17x multiplier, 3.4ghz at 1.5v. But I think this is irrelevant since the rest of the hardware is not configured.
I attach screenshots of my BIOS settings and cpu. Please advise me on what to set these to. I simply want to oveclock my CPU slightly (3.4ghz at 17x multiplier and have my ram run at 1600 at the specified rates that I bought them at.)
I am very frustrated and tired of wasting a whole day on this, please kindly, if you can simply give me the figures to plug into BIOS.
PS: I should add that I did use Google extensively and had attempted on several occasions to modify BIOS to the settings as shown; HT to 2.4mhz etc. But could not modify NB as I only got CPU/NB?? Anyway in most cases computer did not boot, I think because voltage not configured properly. I need to set everything manually.
PHOTOS BELOW:
http://imageshack.us/g/140/1exterior.jpg/
Please help me;
PHOTOS BELOW:
