No problem, if thinking mobo or GPU in particular, I'd try to just get all stable at stock speeds initially, then try OCing the CPU some, get it to a comfortable spot (as that's sort of primary and the CPU OC can help 'Pull' the other components when you start to OC them. Would next work on the GPU and the DRAM last
F3-12800CL9T2-24GBRL/w3680/rampage 2 extrem
