I just finished a new rig based on Intel i7-2600k 3.4GHz on an ASUS P8Z68-V/GEN3 MOBO. I bought two 8GB sets of Ripjaws X model F3-12800CL9D-8GBXL from the same vendor (newegg) at the same time. For each set the SN is sequential between the two sticks. And comparing the first pair with the 2nd pair the SN is only 63 away.
I have not attempted to install my video card (or any other add-on) yet and just am trying to get a clean post install to BIOS with just the MB, CPU, and Mem. So far I have not seen anything come up on the display and I see the DRAM light on solid when I power up. The system actually starts for about 3 seconds, shuts off, then starts up again and stays on. Only the DRAM light is illuminated on the MOBO (plus the power switch light).
The DRAM slots on this board are labeled (from CPU outward) A1, A2, B1, B2. Let's call the sticks from my first Ripjaws set S1a, and S1b. And the second set S2a, S2b.
Here are the install configs I have attempted (all have failed).
1st attempt
A1=S1a
A2=S1b
B1=S2a
B2=S2b
I think this initial config was an error and hopefully it didn't mess anything up.
2nd attempt
A1=S1a
A2=S2a
B1=S1b
B2=S2b
3rd attempt (dropping down to 8GB since I've read where some have had problems using 2 sets of pairs)
A1=empty
A2=S1a
B1=empty
B2=S1b
4th attempt
A1=empty
A2=S2a
B1=empty
B2=S2b
I learned after my first failed attempt that this memory is not on the ASUS QVL for this board and got discouraged, until seeing in this forum where some people have had similar configs work.
I have not yet attempted the MemOK switch as I am not clear on whether there are any disadvantages to using that button and whether I am at the stage where it should be attempted.
I would appreciate any advice to initially get the first 2 sticks working, and hopefully to get all 4 working.
thanks
1st attempt
A1=S1a
A2=S1b
B1=S2a
B2=S2b
2nd attempt
A1=S1a
A2=S2a
B1=S1b
B2=S2b
A1=empty
A2=S1a
B1=empty
B2=S1b
4th attempt
A1=empty
A2=S2a
B1=empty
B2=S2b
thanks
