Model of the motherboard: ASRock Z77 Extreme 9
Model of the memory: G.Skill F3-14900CL9D-8GBSR (2x4GB)
Model of the CPU: 3570K
What is the problem?
First of all im sorry for my probably bad english. I am not a native english speaking person from germany and hope you can help me with my problem.
I have upgraded my system a couple of days before from an old Q6600 platform and now I have some problems due to my small knowledge with the new Z77.
Everytime I set the RAM to his specification of 933MHz (DDR3-1866) and timings of 9-10-9-28 @ 1.5V my system can not start anymore. I have tested different things so far:
1) set RAM voltage up slowly till 1.56v did not change anything
2) changing the slots from 1+3 to 2+4 did also result in bios beeping
3) I also have tried a single module but did not solve my problem either
4) running @933MHz with failsafe timings of 11-11-11-28-2 is also not working
5) all of it again with the newest BIOS update
the only setting that is working for me so far are the failsafe standard settings of 800MHz@11-11-11-28-1 my mainboard is loading after the failed starting attempt.
My system is up to date so I did not overclock anything on it - only thing I wanted to overclock is the RAM because press-reviews have tested this RAM up to 1080MHz@9-9-9-27-2@1,65V 24/7 stable but I do not even get the RAM to his specified settings. My target of overclocking was to get it from specified 933MHz to arround 1000MHz in the end.
XMP Profiles did not help either - everytime I load them pc isnt starting anymore.
I also was wondering about the XMP-Profiles because the first is 889MHz@9-10-9-29-35-2@1.5V and the second
800MHz@9-11-9-29-37-2@1.5V
where is the profile for
DDR3-1866 (933MHz) PC3-14900 @ 9-10-9-28 @ 1.5V like it is praised on the package?
Can you guys please help me to reach my target or at least to use the RAM within its specifications?
best regards
Markus
best regards
Markus
