Hi there
I am currently experiencing problem with my new system (G.skill ripjaws DDR3-1600 PC3-12800 4Gb * 2 and Asus M4A89GTD PRO motherboard)
The problem is that the system won't boot up at all
It's a new system and has never started up, I can't get into the bios as the boot up sequence doesn't get that far, here's what I've tried so far:
1. Disconnect any sata connections and then try to start up the system
2. Try booting up with one stick of memory in different slots.
3. I only have the CPU, graphics card and memory connected presently
4. Cleared the cmos (removed jumper cap from slots 1-2 and connected it to pins 2-3 for 10 seconds)
5. Tried to boot up using one memory stick at a time i.e. each memory stick separately.
6. Cleaned the memory stick connections and the memory slots on the motherboard.
7. Whatever I try and do all I get is 3 beeps (possibly 1 long and 2 short difficult to say)
8. When I tried each memory stick I also tried to use 'memok' utility (i.e. press the button until the led flashes and then allow the motherboard to change any relevant settings).
but all to no avail, I've tried everything I can think of so I would be really grateful if anyone could assist
Many Thanks
Paul
Intended system spec:
ASUS M4A89GTD Pro
AMD Phenom II X4 955 processor
Gskill ripjaws DDR3-1600 PC3-12800 (4Gb X 2)
ASUS EAH5670
Hitachi Sata 1.5Tb HDD
GX Lite 700W PSU
Many Thanks
Paul
ASUS M4A89GTD Pro
ASUS EAH5670
GX Lite 700W PSU
