Hey ive being having trouble getting the right RAM can you please help i just bought G skill ripsaw 3x4gb F3-12800CL9T-12GBRL because the model number was listed on my mobos evga website, but now i see your website its not in the list.. do i need the blue model ones?
EVGA X58 Sli micro, Ram solution
oh no
well actually now i installed my old ram back in super talent 2x2gb WA133UX6G8, its now doing the same problem but not completely system crashing like with the g skill in earlier with a green light on only then have to switch off from wall. its now crashing to a black screen then i have to ctrl alt delete to get out. few times it restarted itself, gfx card is still new and psu is new but maybe **** cos its a GX750 coolmaster, could this psu have gone right when i tryed out this new ram? any ideas, my com was fine untill the gskill went in... Would a format fix this by any chance lol?Last edited by Lathan; 06-02-2012, 06:25 AM.
yes XMP just dasnt load at all then i have to quickly load defaults in bios before it crashes, when i installed lastest bios update the bios date changed but its different...to the date i was told. also i didnt pull out the power cable and hold cmos reset button, but nothing was wrong untill i tryed this new ram other day, so could this really be the issue? and why cant i just run my old ram and everything back to normal? this all seems like a g card problem? is it in anyway something else? my card is new but had water damage, so could easily be the problem until i check it on anther pc
