Hi
Have been having a great many issues with a new build PC (my 1st for approx 10 years, have been using a 2.4Ghz AMD single core all this time!!!)
Have stripped, and am rebuilding the rig, to test everything.
I have found in both the BIOS (flashed to latest version 3801) & MEMTEST 86+ - which is running currently - that the RAM is showing as 11-11-11-28. This is also true with XMP enabled.
Is this correct? Both motherboard manual & the RAM sticks themselves state the settings should be 9-9-9-24 2N? Is there a reason the motherboard is not recognising them?
FYI, the XMP enabled reads "profile 1" and shows 9-9-9-24 2N however this doesn't - as stated - appear in either the "AI Tweaker" DRAM Timings settings, nor in MEMTEST.
Many thanks in advance & apologies if this appears a "n00b" question!
