I wish to expand my Sabertooth (AMD "Thuban" Phenom II X6 1090T).
Now I have a F3-12800CL7-8GBRH kit (2 x 4GB), set at 1600 MHz, CL7-8-7-21-28, CR1, 1.6V.
Here in Italy I haven't found the same kit. It disappeared...!
Can you suggest a possible alternative to this kit? Can I mix different products but with similar timings?
I have another question: will I have to relax my actual timings? I know that AMD IMCs are a lot critical in stability when used with 4 RAM modules...
