I'm trying to figure out *why* i'm unable to set this ram to the XMP profile without boot loops. Long story short, On boot it loads DDR3-1333 (DRAM Frequency). I have one option in bios. Select `load xmp setting` and there i have xmp 1.3 profile 1 (or 2) reading the correct 2,400 specs.
If I select the profile the computer reboots (a few times), finally it comes back and takes me directly to the bios. at which point everything is set back to 1333.
Think i've notice. The other choice in bios is to select DRAM Frequency and that seems to work better. I can select up to 2,200 and the system boots without issues. selecting 2,400 results in the same issues as using the XMP profile.
What can I do to get this xmp profile working at the 2,400 speed.
Specs;
. +Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
. G.SKILL Trident X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 2400 (PC3 19200) Desktop Memory Model F3-2400C10D-8GTX
. ASRock Z77 Extreme6 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Specs;
