Not most but all, DIMMs 1 through 5 all had errors in Prime95 then I upped the voltages and tested DIMMs 5-8 and then back to DIMM 3 and no more errors. I went back to DIMM 3 because I had run it 4 nights and it always had errors at stock. If I put the voltages back to stock I’m think they will all have errors. I only had the one DIMM from a friend but it had no errors running at its stock settings. I don’t know anyone with a 2011 CPU.
I did look over the CPU socket as I’d seen some stuff online about bad 2011 pins killing CPUs and the motherboard makers telling people they must have damaged them. I feel confident there is no compound passed the heat spreader.
Also, I was able to run Prime95 with all 8 DIMMs and not get errors at first. The first thing I did after getting the system together was run Prime95 for two nights and a run of Memtest86+. It also makes me wonder because there are three posts (two verified owners) on Newegg that say the DIMMs start to fail after a month or so. Then there is one more that simple says it was bad and he returned it. I thought maybe they did not know what they were doing or were crazy but now I’m thinking they were onto something. At the same time, in 20+ years and many builds I’ve only seen bad RAM like two times.
