I got the Ripjaws Z Series 64GB (8 x 8GB) F3-12800CL10Q2-64GBZL kit for my ASRock X79 Extreme 9 motherboard with an Intel 3930k CPU.
I got this kit as my motherboard is on the Qualified Motherboards List.
http://www.gskill.com/products.php?index=432&c1=1&c2=3
I have the latest 2.0 BIOS for the motherboard.
I am not over clocking anything. All settings are at stock.
I was able to select the XMP 1.2 profile manually in the BIOS and it shows the RAM running at DDR3-1600 speed.
I?ve been running the system for about a month now and it is not stable. I do not get a BSOD screen, everything just locks up or freezes and I must power the system down and reboot.
I?ve had it lockup twice in one day but it has also run for as long as 2 or 3 days without a lockup.
I?ve run MemTest 86+ 4 or 5 times overnight and it has not shown an error.
When I run Prime95 I get an error on one of the threads within 30-40 minutes. I?ve only used the Blend test setting.
The CPU is water cooled and it?s max temperature for the hottest of the 6 cores under load is 53?C using Real Temp GT 3.70.
I'm going to try disabling the XMP profile and lit it run at DDR3-1333 and see if that helps.
