Hopefully there is a solution to this issue:
Please tell us the details of your system specifications
Model of the motherboard: GA-P67A-UD4-B3 (F7 BIOS)
Model of the memory: F3-2133C9D-16GXH
Model of the CPU: i7 2600K
What is the problem? example: no boot, blue screen, reboot...etc.
I can't seem to get the my RAM to exceed 1600Mhz, when it's rated at 2133Mhz. I've updated my BIOS to the most current revision, manually set the timings/voltage to G.Skill Specs and turned off XMP.
If I configure anything higher than 1600Mhz for the ram, the BIOS will not post until it has reverted back to 1333Mhz.
The system has been stable for a year with two sets of F3-17000CL9D-4GBXL, but I wanted more memory. So, not wanting to limit myself with a motherboard claiming 32GB capacity, I chose to get a 16GB dual channel kit.
The motherboard compatibility listing for the F3-2133C9D-16GXH kit lists the GA-P67A-UD5-B3 motherboard as being compatible and there is very little difference between the UD4 and UD5, so it seems probable that there is a way for me to get this working.
Tonight I plan on trying other BIOS revisions/settings.
Thanks!
Thanks!
