Hey guys, I just recently bought 2 Ripjaws X kits, one for my wife's computer and one for mine. We each have 16gb of the PC-10666(1333) CL7, my wife's is running fine but I have had my system lock up a few times with the last sound that was played repeating over and over. This happened the last time we got new RAM with her machine, we swapped RAM and then mine was the one having the same problem. I replaced it and it was indeed the problem. I ran Memtest86+ last night and had 67 errors in 3 passes, it's safe to assume I may have a bad module. All settings on mine and my wife's systems are the same, 7-7-7-21-2T at 1.5 volts, which is what the RAM states it should operate at. I purchased these from newegg so I should try to RMA with them first correct? Thanks for the help guys.
-Mike
Phenom II X4 945
MSI 770-C45
EVGA Geforce GTX 550 Ti
Windows 7
-Mike
Phenom II X4 945
MSI 770-C45
Windows 7
