Hello!
I just upgraded to an 8gb kit! Went to BIOS to manually configure, but found more settings that if not properly set may result in system instability. Searched google and the forum, but couldn't find much information as far as specific settings for this particular kit.
Motherboard: BIOSTAR T5 XE LGA 1156 Intel P55 ATX Intel
Memory: F3-10666CL7D-8GBRH
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3
CPU: Intel Core i7-860
BIOS: Latest (according to BIOS update software)
DRAM frequency 1333MHz
B2B CAS# Latency Disabled
Channel Interleave Auto
Rank Interleave Auto
DRAM tCL 7
DRAM tRCD 7
DRAM tRP 7
DRAM tRAS 21
DRAM tRRD ?
DRAM tWR ?
DRAM tWTR ?
DRAM tRTP ?
DRAM tRFC ?
DRAM tFAW ?
DRAM Command Rate - Auto / ?
The voltage is currently set to Auto.
Here are screenshots of auto-detect settings. It seems to be stable.
DRAM tCL 7
DRAM tRCD 7
DRAM tRP 7
DRAM tRAS 21
DRAM tRRD ?
DRAM tWR ?
DRAM tWTR ?
DRAM tRTP ?
DRAM tRFC ?
DRAM tFAW ?
