i (maybe) want to replace my F3-12800CL10Q-32GBXL Kit with the F3-2133C9Q-32GXH
Did i have a chance to run this kit with the Intel DZ68BC?
I already own a 16GB kit @DDR3-1866 F3-14900CL9Q-16GBXL,
but this kit won't work with this mobo (with a 2500K cpu)
Now i own a 2700K cpu,
the question is ( F3-2133C9Q-32GXH)
you write the memory needs 1,6V - but this can damage my CPU !?
When the kit doesn't work @DDR3-2133 CL9,
can i run the memory for example @DDR1600-CL7 with lower voltage?
I think the 32GB kit i already own and the CL9 Kit "F3-1600C9Q-32GXM"
are the most compatible memory kits for the most board.
Can i run the F3-1600C9Q-32GXM for example @ DDR3-1866 CL10?
is it maybe possible?
Thank you very much for your help.
