I'm having trouble getting stability with F3-12800CL9D-8GBSR2 x2 kits for 16GB (x4 sticks total) at 1600 in a Gigabyte GA-Z68MX-UD2H-B3. I'm using a 2600K CPU in this setup.
Using any combination of x2 sticks in either DIMM slots 1&2 or 3&4 work fine using profile1 XMP settings.
When I add the extra pair of sticks, I start failing memtest86+ v4.20 tests.
It goes up to the tail end of Test #5 [Block move, 80 moves] and starts dumping errors consistently at that point. Multiple tests and moving the sticks around always results in the failures at the same place.
I tried changing the timings to 9-10-9-28, bumping the QPI/VTT voltage to 1.1v, and the mem itself to 1.3v (these are low voltage 1.25v spec dimms).
I'm not OC'ing anything as I want simply stock speed and stability at this point.
Any other ideas??
Any other ideas??
