F3-14900CL9D-8GBSR settings
  • F3-14900CL9D-8GBSR settings
    phenom II x4 955BE
    asus cross hair V formula
    F3-14900CL9D-8GBSR
    I was wondering if someone could tell me what settings i should have my memory set to. Also I was wondering if the 955 is capable of handling memory at speeds of above 1600 and if not will I be able to overclock the timing since the sticks wont be running at full speed.
    Depends on the combo of mobo, CPU and the sticks, with your setup it could vary from one to another on two identical rigs. Generally look to a 965 C3 to run 1600 or better, but some 955s have done so. There's a thread that talks about running and setting up 1600 with AMD here:
    With the sticks you have for 1600, might try 8-8-8-26.....AMDs are touchy w/ DRAM and even between the same models of CPU, some can do what others can't
