Gents,
I'm doing a new build. The mobo is an Asus M5A88-M with a Phenom II x3 720 BE.
The mobo is a mATX. I want to minimize heat/cooling needs, so I was happy to find some G. Skill memory labelled "Low Voltage". Cool. Before I bought it, I wanted to verify that it was compatible with the specific mobo listed.
The memory is: F2-12800CL9D-8GBSR2. It is a 2x4GB pair.
I was told it was compatible.
It was not.
The machine would not post. Substituting in my trusty backup G. Skill memory (a different 2GB card) the mobo POSTed right up.
In order to get a refund through Newegg, they're charging me a restocking fee. Very uncool.
I would not have purchased this 1.25v memory is I hadn't received email confirmation from G. Skill that it would work.
Soooo. Since it won't even POST, I can't do anything with the memory/timings/voltages. Before I'm out 7 1/2 bucks, does anyone have any (helpful) suggestions?
(Hey, G. Skill, if we can't get it to work, do you mind sending me the restock fee?)
Thanks,
Ken
It was not.
Thanks,
Ken
