My setup it atm:
Motherboard: ASRock H61M-VS (With BIOS up to date - V 1.30)
CPU: Intel i5 2500
RAM: F3-10666CL9D-8GBSR (just the 2x4GB)
Now the "funny part", the MB settings on "auto":
RAM settings:
DDR3-1066
7-7-7-20-1N
(8-86-4-4-4-16)
Voltages:
CPU Core Voltage Offset: +0v
IGPU Voltage Offset: +0v
PCH: 1.059V
CPU PLL: 1.833V
VTT:1.057V
DRAM: 1.600V
VCCSA: 0.925V
With this settings i get some mem errors on load in some applications but if i put the "box settings" of the ram:
DDR3-1333
9-9-9-24-2N
DRAM: 1.500V
Its completely not stable....
any help please?
And yes, i have run memtest86+ with both and separated and in reversed positions and no errors on 5 runs.
Thx in advance.
CPU: Intel i5 2500
RAM settings:
DDR3-1066
7-7-7-20-1N
(8-86-4-4-4-16)
Voltages:
PCH: 1.059V
CPU PLL: 1.833V
VTT:1.057V
DRAM: 1.600V
VCCSA: 0.925V
DDR3-1333
9-9-9-24-2N
DRAM: 1.500V
any help please?
Thx in advance.
