New Build - have a problem.
running windows 7 ultimate.
I5 processor
Gigabyte Mbd GA-Z68A-D3H-B3 motherboard
After increasing the memory from 2 dimms installed ( 2x4g Gskill ripjaws F3-8500CL-7D-8GBRL) ddr3 up to ( all 4 DDR3 dimms installed - all 4 same type) now keep getting blue screen crashes.
running the windows memory test on initial boot up - get "hardware failures"
I then reduced the memory to just 2 DDR3 dimms installed, and the bootup windows memory testing passes. Cycled thru all 4 of the DDR3 memory modules, and they all pass as long as only 8G in the mother board.
fail memtest w/ 4 dimms, pass w/ 2 dimms
SO...I'm assuming the mother board is bad.... ????
using all default bios settings
I5 processor
