AMD 1090t
Asus M4a89gtd Pro Usb3
G.Skill Sniper GSkill Sniper F3-12800CL9D-8GBSR2 1.25v
I just upgraded from Ripjaws F3-12800CL9D-4GBRL to G.Skill Sniper 8g 2days ago & i set the timings at 9 9 9 24 1t 1.25v. 1T because i read some reviews that if you can run it at 1t then much better so far everything is okey but i notice some delays on switching on application unlike before when i still use my 4g ram.
Already memotest for 5hrs with no errors. By the way before installing the ram should i reset CMOS or do anything else because i just put it in and run, i was thinking that this kit is slower than my old ram or should i tighten timings & what timings is best?
I saw someone on newegg running at 1333Mhz with 7-7-7-20 1T timings but its the G.Skill F3-12800CL9D-8GBSR 1.5v
Hope you help me Thanks!!
