I'm having trouble with this particular combination of motherboard and memory:
Model of the motherboard: Gigabyte GA-990FXA-UD3 (rev. 1.0) http://www.gigabyte.us/products/prod....aspx?pid=3894. BIOS version is F4.
Model of the memory: [ RipjawsX ] F3-14900CL9D-8GBXL http://www.gskill.com/products.php?index=378
Model of the CPU: AMD Phenom II X6 1090T Black Edition Thuban
I am getting intermittent errors in memtest86+ 4.20. Which tests produce errors varies and the addresses affected varies, but the error bits are always either 00000200 or 00000400. This suggests to me that it may be a compatibility issue with this motherboard, and I am hoping someone can either confirm this or provide an example of working timings and voltage, or make a suggestion that helps me to produce a working config.
I've tried several configurations, set manually as directed, including:
Method #2 from this thread: http://www.gskill.us/forum/showthread.php?t=7688
CPU NB VID: 1.250 V Clock: 2400 MHz
DRAM: 1.500 V Clock: 1600 MHz Timings: 9-10-9-28-2
Fail safe:
CPU NB VID: 1.150 V Clock: 2000 MHz
DRAM: 1.500 V Clock: 1333 MHz Timings: 9-9-9-24-2
Motherboard fail safe:
DRAM: 1.500 V Clock: 1600 MHz Timings: 11-11-11-28-2
Currently testing:
DRAM: 1.500 V Clock: 1066 MHz Timings: 7-8-7-21-2
I've also tried a few other variations by bumping CPU NB VID a little more and DRAM voltage up to 1.55 and 1.6 V, but I still get errors eventually.
Is there anything I can do? If I have to I'll buy a different set of memory and just chalk it up to inexperience since this is the first time I have ever built a computer from scratch, but if there's something I'm missing and there is a configuration that should work I'd like to try it. I'd rather not raise the FSB if I can avoid it.
Even if there isn't a working config, I would consider buying from G.SKILL again. I've been very impressed with the forum activity here.
Thanks,
John
Fail safe:
Currently testing:
Thanks,
John
