Problem With 16 GB
  • Problem With 16 GB
    Good Morning Everyone, to start I want to thank any help I could provide
    English is not my mother tongue, I will try to be as clear as possible
    Here I go:
    I bought a few months ago this PC:
    AMD Phenom II X6 1090T Black Edition Hex-Core 3.20GHz
    Gigabyte GA-890GPA-UD3H AM3 890GX ATX
    G.Skill Ripjaws Series 4GB 240-Pin 1.5V DDR3 SDRAM 1600MHz (12GB)
    Ati Msi 6950 Twin Frozr III
    Cooler Master GX750 750W
    Hard Disk, Case etc.
    I never set anything( Like Bios), the computer works correctly
    well, 1 week ago I bought new Memory (for finish my 16GB)
    and that's when the problems started, the pc restarts when I am in heavy gaming,
    I changed the position of the memories and still the same
    when I remove the new memory, the pc works fine, but when I leave that memory and one of the old bag, the pc locks up in games
    thinking that are not compatible I noticed a detail in the models:
    these are my old memories:
    F3-12800CL9S-4GBRL
    DDR-1600 PC3-12800 4GBX1
    CL 9-9-9-24 1.5v
    and the new is:
    F3-12800CL9S-4GBRL
    DDR3-1600 PC3-12800 4GBX1
    XMP CL9-9-9-24 1.5v
    I thought it was the same and now are giving me this headache I called the store where you buy them, and tell me they do not have the model I have. Neither money back, I feel a little bad about this.
    these memories can work together? which is what I have to do
    I already update my bios with tool @bios
    Thx for read this
    So you have bought 4, single stick packages..with each stick being 4GB? Might take a look at the sticky
    to get a basic setup for 1600 stick, and then will probably have to experiment by raising DRAM Voltage and CPU/NB Voltage, it's best to buy a single complete set i.e. 4x4GB of 16GB, that way they are tested to work together, next of course would be 2 sets of 2x4GB, which can have problems not wanting to work together especially with an AMD CPU, worst case scenario is buying 4 single sticks.
      thx for reply... I bought first 3 memorys
      this
      F3-12800CL9S-4GBRL
      CL 9-9-9-24 1.5v
      and 1 week ago I bought this one
      F3-12800CL9S-4GBRL
      XMP CL9-9-9-24 1.5v
      1. That can work together?
      2. I saw the tutorial "AMD CPU + G.Skill DDR3-1600 ", I have a question, can my 16gb work with 1600 mhz. or I need to change to 1333
      thx
        The CPU yopu have is capable of running 16GB of 1600, the mobo also can run it....the problem you may have is running the sticks you have since you didn't buy them as a complete set, set are tested to be sure all sticks work together. No matter what type of DRAM you get, if you get the sticks in separate sets or individually they may have trouble playing nicely with each other, oft times as they come from different production lots and the materials may also have been from different production lots, the tolerances can differ microscopically and create problems....if it won't work at 1600, yes you can oft times drop to 1333 and tighten the timings i.e. if your sticks are 9-9-9-27 you can go 1333 with 8-8-8-24 and they will work and have near same performance as 1600 native due to the lower CL at 1333
          Thank very much
          Sometimes the seller just think about selling and not explain this and we are the customers who pay the Consequences, also agree that I have some guilt.
          CPU-Z shows me this information.
          DRAM Frequency 803.6 Mhz
          FSB: DRAM 1:4
          CAS # Latency (CL) 9.0 clocks
          RAS # to CAS # Delay (tRCD) 9 clocks
          RAS # Precharge (tRP) 9 clocks
          Cycle time (tRAS) 9 clocks
          Bank Cycle Time (RRS) 37 clocks
          Command Rate (CR) 1T
          which will have better performance, the configuration I have currently 12 GB with 1600Mhz or 16GB with 1333MHz
          voltage is 1.5V
          ty a lot
            Are the settings above for the 12 GB? if so, might be able to get the 16GB to run stable by simply changing the CR to 2T (better for fast sticks and AMD MCs)and possibly raising the CPU/NB voltage a tad
              yes, this is the default configuration. works well. in these months I never had any problems, the detail is when I put the new memory, the pc just restarts in heavy gaming, I can spend hours on msn and normal, the problem is when I demand.
              I will do what you say on the CR to 2T, but you mean exactly CPU / NB?
              CPU Voltage Control
              NB voltage control
              CPU NB VID Control
              I'm a little confused on this part
              my motherboard is a GA-890GPA-UD3H
                CPU NB VID, let us know
                  I got blue screen
                  PAGE_FAULT_IN_NONPAGED_AREA
                  I change CPU NB VID, 0.100v +
                  and set 9-9-9-24
                  Command Rate 2T
                  what can I do now
                    CPU NB Frequency 2400MHz?
                    Post some pictures of BIOS and we can see if anything is incorrect.
                      I didnt change CPU NB Frequency before, but now I did,
                      now my config is this
                      I am testing with this config now but tell me if something is wrong please.
                      pic1
                      http://img855.imageshack.us/img855/2...0820115128.jpg
                      pic2
                      http://img718.imageshack.us/img718/2...0820115129.jpg
                      pic3
                      http://img11.imageshack.us/img11/5712/310820115130.jpg
                      pic4
                      http://img217.imageshack.us/img217/7...0820115131.jpg
                      pic5
                      http://img97.imageshack.us/img97/5752/310820115134.jpg
                      thx
                        I got other type of blue screen, was a little fast I didnt check which was, but was something like this
                        "...if this is the first time you've seen this error screen, restart your computer..."
                          Did you restart and try again?
                          Test one at a time with those settings.
                            I did with the same config and restart again idk what is happening, or i need to change to 1333 mhz ??? something in my config bios is wrong?
                              Try DDR3-1333 8-8-8-24 1.50V
                              It is possible the two sticks are not compatible because they are not from the same kit. In the future, make sure to purchase a dual channel kit for a dual channel motherboard.
