Hey,
I had in my computer:
Processor: Phenom II X4 955
Motherboard: ASUS M4A79T deluxe
VGA: ASUS ATi Radeon HD4890 - 256bit
Memory: ADATA TRIPLE DDR3 bus 1333Mhz Overclock Stand
OS: Windows 7 Enterprise x64
Then I switch the ADATA's with the kit F3-12800CL9D-8GBSR. But It works quite unstablely.
I take a look at the Motherboards List in http://www.gskill.com/products.php?index=390 and I don't see M4A79T deluxe on it. So does it mean I have to go on with another kit or is there anyway to fix the problem?
Plz help.
Thanks a lot.
Plz help.
Thanks a lot.
