Could you please help me find the best settings for my hardware.
I'm having a hard time trying to stabilize a Asus M4A89GTD PRO USB3 and AMD 1090T running 4x4gb sticks F3-12800CL9D-8GBRL (that came from G.Skill RMA# UR2112686).
The memory was recognized right on the first attempt but the computer freezes or shows blue screens all the time. It's impossible to run Prime95 or even copy a 500mb folder.
I've tried all settings, including default, everything I found in this forum, all Asus recommendations. Nothing makes this system stable: I can't run Prime95, nor copy files nor run an application like Firefox or Photoshop without a freezing, after 1 or 2 minutes.
This motherboard is the third RMA replacement.
The first one worked fine for 6 months, with 8gb F3-12800CL9D-8GBRL.
The second one worked fine for 2 days, with 16gb F3-12800CL9D-8GBRL. I was using the settings I found on the forum and I had not a single problem, I could run Prime95 during 45 minutes @48?C. The system was stable and fast. Then I was running a monitor calibration software when it froze and stopped working (no more boot, nor post, nor beeps).
Because of this, I think I have my third Asus faulty motherboard in 40 days! Before the fourth RMA I'd like to try all possible settings.
Thanks a lot for your help.
Fernando
Fernando
