M4A89GTD PRO/USB3
12800CL9D-4GBXL (2 for a total of 16gb)
AMD 1090T
ATI 6850 x2
Ok so I have read through through several threads so far and followed the guide exactly. I have no stability problems whatsoever. However the only issue I do have is that the Bios and Windows doesn't recognize all 16gb of ram. However programs like Speccy show that all four slots are filled and shows the speeds/latencies. So I don't know what the exact problem might be, I figured this was the best place to look. Just fyi, my settings are that of the guide as far as voltages are concerned. Thank you in advance for the help!
Russ
AMD 1090T
ATI 6850 x2
Russ
