I am trying to get 16gb of F3-10666CL7D-8GBXH ram to work on a 790FX-GD70. The 4GB sticks I'm using are working perfectly at 7-7-7-21 @ 1.5v when only using 2 of them for a total of 8GB. It's when I try to fill up all 4 dimm slots that I get a problem. The computer will boot with the recommended settings, but when I reboot, the system hangs and I have to power down then free up 2 dimm slots to be able to boot again. I read a post about the amd memory controller limitations and I'm unsure if that includes my motherboard, but it would not surprise me seeing as I'm having problems rebooting with 16GB. I've tried upping the voltage a little and still no luck. The highest I went was 1.54v. Will I have to lower my speed from 1333 mhz in order to use 4 dimms?
Current build specs:
MSI 790FX-GD70 AM3 AMD 790FX ATX AMD Motherboard
G.SKILL Ripjaws X Series (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL7D-8GBXH
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor HDZ955FBGIBOX
SAPPHIRE 100259L Radeon HD 4870
