Does anybody know if the F3-12800CL9Q-16GBXL set is compitible with a crosshair v board? Ty all for answers.
F3-12800CL9Q-16GBXL compatibility with crosshair v
Should be no problem as long as your CPU will carry them at 1600 - could take a look at the sticky on setting up 1600 sticks, here:
Depends which CPU you have, if it's a C2 Denab, then you may have difficulties.
The Thuban X6 and C3 Denab CPU's should run 16GB of 1600 memory fine.AMD Phenom II X6 1090T@ 4.2GHz
ASUS Crosshair V Formula
Creative SB X-Fi Xtreme Gamer
Corsair HX850W Modular
2x Win 7 Home Premium (x64)
