which memory series full compatibility with Asus M4A89GTD PRO/USB3?
  • which memory series full compatibility with Asus M4A89GTD PRO/USB3?
    Hi greatings from Turkey.
    I looking G skill 4GB(2x2) or 8(4x2) 1600Mhz/2000 MHz DDR3 Ripjaws X / flare series full compatibility memory for my new Asus M4A89GTD PRO/USB3 model mainboard.
    I need 2 advice about 4GB(2x2) or 8(4x2) Gb memory kits. waiting for model number.
    Model of the motherboard: Asus M4A89GTD PRO/USB3
    Model of the memory: DDR3
    Model of the CPU: AMD phenom II x4 955BE or 965BE
    Will want the 965, think I'd go with a 2x4GB set (4x2GB, having 4 sticks will put additional load on the IMC with 4 sticks) , for 1600 will require an OC to run, can see the sticky
    Believe I would suggest reg Ripjaws or Snipers for your setup and at 1600 prob CL9....maybe CL8 sets
      Tradesman
      I want only run 1600Mhz stable with my mainboard. I do not think O.C for now.
      ı need advise for Memory model. 2x2 or 4x2
        F3-12800CL7D-4GBXM thiss series can be work without problems?
          Yes, very good kit.
            Yes, very good kit.
            I know it is nice kit
            I ask it can be works stable with M4A89GTD pro usb mobo
              Yes, very good kit to works stable with M4A89GTD pro usb mobo.
                thank you for help! . I get order this night.
                  Let us know what you think
                    sorry ))
                    I saw in one store F3-12800CL9S-4GBRL (1 piece) and I bought it.
                    I think I will buy another one in 2 month I am sure it can be work dual.without problem
                      Should, but could have problems mixing even the same model of sticks, especially if the come from different production lots. Let us know how it goes.
