Excuse my English, I am a Italian user.
My setup
Intel I7 2600 K
VGA Gainward GeForce GTX 570 GS-GLH Core 800MHz Memory GDDR5 4000MHz 1280MB
Hard Disk Hitachi 7K3000 2TB 3.5" 7200rpm 64MB SATA3
.RAM DDR3 G.Skill Ripjaws-X F3-10666CL7Q-16GBXH 1333MHz 16GB (4x4GB) CL7-7-7-21 1.5v
Asus P8Z68-V PRO Socket 1155 Intel Z68 DDR3
Corsair 850 Watt
Zalman 9900 MAX
I have random problems of instability, the system freezes during heavy work or during normal activities is no different.
I have to reboot the computer, reading around the problem should be due to instability of the ram, I would like to know if there is any manual method to set them on a regular basis or there are memories of working (really) for this motherboard?
The temperature of the CPU at full speed is around 60 degrees
Only I have had these problems?
For now seems stable with 8 GB, I set to 1.50 V and 7-7-7-21 in the bios, but I know there are other problems, I would like to have a stable configuration, you have any advice?
My setup
Intel I7 2600 K
Corsair 850 Watt
Zalman 9900 MAX
