Hi..
I want to ask a question. lately my computer freezing alot. well, this is happening before, but it just gone after i overclock the RAM a bit. but now it getting worse after i change to a bigger screen (17" to 22"). and more worse (maybe because the bios setting is back to default) after i return the motherboard because the ethernet problem...
Now i don't know which one is the main problem. but after i overclock the RAM, it's getting better. but still won't fix the problem. and when the computer freeze, the VGA fan will spin to max rpm. can you diagnose this problem and help to resolve it, whether i need to change the parts or change the setting?
Thanks..
my Spec:
AMD Phenom X4 940 BE
DFI LP DK 790FXB-M2RSH
Sapphire R4850 512 MB
G.Skill DDR2 10600 4GBNQ
Windows 7 32 bit
Thanks..
my Spec:
Windows 7 32 bit
