The F3-16000CL9D-4GBRHD is advertised as 2000Mhz, but with a Sandy Bridge board, I can either run it at 1866 or 2133.
Currently running it at 1866Mhz, as the XMP profile suggests, on an Asus Sabertooth P67. The RAM appears on the QVL for this board and passes memtest and prime stress tests at 1866Mhz, with the default XMP profile values, 9-9-9-27 and 1.6v.
My question is how safe is it to run at 2133Mhz? Have you done any testing at 2133Mhz and if so, what are the recommended timings/voltage for 2133, if at all?
If running it at 2133Mhz is not recommended, can I lower the voltage a bit or tighten the timings a bit if only running it at 1866Mhz?
Thank you for your time,
oldseeker
oldseeker
