Hello.
Bought a new rig, got it together today.
I keep experiencing the debug code 45 on this motherboard. I have tried every possible placement of RAM on the motherboard, and cleared CMOS completely between every placement. Even tried different RAM. No luck.
I tried removing the CPU and then place it back into its slot, and still no luck. It will point to debug error code 45 unless I completely remove the RAM. At this point, it will point to debug error code 22, which is normal.
Any suggestions to what can be at fault?
Asus Maximus IV Extreme B3
i7 2600k
G.Skill F3-12800CL9D-8GBXL
Thanks, Tony
i7 2600k
Thanks, Tony
