Hello all,
I would like to discuss some issues I have been having with the above mobo and combo.
First, let me refer everyone to this thread:
ASRock 870 and F3-12800CL9D-4GBRL
Little background.
I built my current rig last November.
It was running great for about 6 weeks, then I started to get random freezes. It was during gameplay, sitting at the desktop, just really random to it.
I did memtest and initially thought I had found a bad DIMM, which I RMA'd and received back.
After I received the memory back, everything seemed to be ok for a couple of weeks, then it starts up again. Freezes during game and even saw two BSOD's.
I took everything apart. Testing this, testing that. It thought I had heat issue, but I didnt.
To make a long story short, I started researching again when I came across the thread posted above.
Needless to say, after A LOT of hours of frustration, trying to figure out WTH was going, kinda feel like I have some idea on how to resolve this. I am posting here because I still have questions on how to properly get things 'timed' and I am hoping for help here.
I read the thread above and tried to take from that and apply to my situation. Now, I am really young when it comes to Overclocking anything. I still have a stock heatsink on my CPU, but that is going to be replaced here in the near future.
I also wanted to show this thread as well:
AMD CPU + DDR3-1600
I read that as well.
So, here is where I am at.
I want to make sure I can stabilize the timings on the memory to get rid of the freezes and BSOD's. Once I get that down, I would like to run this memory at DDR3-1600 speed.
So my questions are:
1.) For those out there and G.SKill tech support, have you seen this issue at all with this particular setup? If so, what were the specific settings that need to be adjusted?
2.) Is it still possible for me to get to DDR3-1600 speeds?
3.) Lastly, tips for getting the memory clocked properly? I am still learning here.
So what I have done lately is change the voltage on my memory.
When I first looked in the BIOS, the voltage was at: 1.54 and this memory is 1.5.
The only next step down was 1.47, which is what I put it at.
Reading the above thread by GSKILL TECH, trying to get DDR3-1600 speed, I did set the DRAM Frequency to DDR3-1333, but wondering if I should not do that.
Anyway, long thread, just really looking for some help and feedback on how to stabilize this as well as get DDR3-1600 speeds.
Thanks for the help.
TCG
Little background.
AMD CPU + DDR3-1600
TCG
